Ideally, yes, I'd like to, but it'd have to be some hefty standoffs. Maybe some steel tube legs mounted to MDF? Then I could bolt the unit to the MDF, point it towards my back, and bolt through the MDF and tubes into the rear bulkhead. That could work...Darkangelv2 said:That does look nice.
Will you add standoffs and mount it so it fires into the cabin (at the firewall) or have it firing into the boot, away from you?
So, with this, I'm in 2 minds; is it better to hard mount the base to the bulkhead (maybe with some sound deadening matting sandwiched in between) so as to get the reverberations through the bulkhead but have it facing backwards and then allow it work within the rear compartment, or face it forwards towards my back to have it 'do it's thing' towards me. Will that limit it's output if it's effectively hanging in the air? I'm not an audiophile (but enjoy good quality music), so I'm not providing proposals, merely asking questions!Darkangelv2 said:Yeah, that was what I was wondering. That could work I’d guess![]()
Thanks. I'll rip off the trim this week and ponder....Darkangelv2 said:Bearing in mind Liam’s racecar build, you could also cut a hole in that wall if you wanted.... it’s not structural :evil:
Like you, I’m not an audio expert and don’t know which would benefit you most.
Thanks! Yes, it's not earth shattering, I mean I didn't even know it was working, and then I went out this morning to just crank everything up 'till the max and then it came to life. Yes, but it's good. I now have to tune it up and get the balance right.Darkangelv2 said:Looks a great job. Same issue with the LH speaker wires - far tighter than the right. Happy with the bass fill you’re getting?
