For some reason i have been blocked from signing on as bigendbob so have reregistered as flybobbie.
I will try to put something together so that you can see how to get the light units off.
I wonder how many not on the forum have these problems. My colleagues car as done 6k and has the problem, and have seen others.
To have a quick look;
Open boot.
There are four pieces of trim to remove, 3 black plastic and 1 with the grey carpet material.
Work from the highest piece of plastic, remove the 3 plastic push pins with a blunt knife. Next the piece below is clipped on so pull it towards the front and it will unclip.
Next is the curved piece with the access panel to bulbs, remove further 3 push pins (bit of a challenge to find the third one!). Close boot. Open the boot as though stowing roof, and this piece of plastic can be withdrawn. Close boot and reopen from rear. Finally remove push pins from grey carpetted piece, don't forget the one under the little door.
This should expose the rear bulkhead. Unclip the electrical connector.
I found it safer to remove all bulbs.
Next remove 3 10mm a/f nuts.
Finally from out side pull the lamp out starting at the pointed inboard end as there are two locating pins that fit into the rear quarter where the lamp housing curves. If you look on the inside there two black rubber oval shaped seals these will come away with the lamp unit.
Refit in reverse, making sure the oval seals reseal otherwise water will get into boot.
Forgot to mention may need to pull up the rubber boot seal above the lamp assembly.
Overall a crap design.
Once the lamps are out, there are plenty of access holes to blow warm air from a air dryer to dry out unit after the worst has been shaken out.
Then the piece of plastic on the rear shaped like goggles can be unclipped, be careful as the clips are fragile. This will then expose the culprit. The rubbish rubber they have used to seal the unit. Squeeze the seal and you probably find water drips out, because its not closed cell foam, a pretty basic error where ip grade sealing is required.
Wouldn't suprise me with all the euro crap that the car manufacturers have gone all self certification when it comes to lamp design as in the traffic light industry, and this is the result. Come back the BSI!
