Comfort access ?
  • Start date Start date
Yes Ronk but I couldn't set that feature as my OBD Bluetooth isn't a Carly one so connection wasn't sufficient :cry: I need to buy the Carly one now. It's (as you say) the feature I need!!
I suspect that you will not be able to control the roof. The dealer tried for me and couldn't get there even with his access to the system.
I'm told that operation of the roof via external means was prevented after a child had his fingers trapped when his father closed the roof.
Mine shows that I can but I guess I won't be sure until I try it, if not it will be 'smartop'
The mechanism is just as likely to cause injury opening as closing.
I was told that the child was standing and holding the top of the 'screen when the roof closed onto his fingers.
Litigation ensued!
If you read other posts in this string, Dave and I have tried it with Carly and even when you tick all the right boxes you still can't close the roof from the fob - the only improvement is that you can close it with the key in the door in the lock position. So I am pretty sure that Ronk is right - the function is there, but something else has been put into the programme to stop you closing the roof at a distance. Sorry to repeat myself, but I don't think you have seen the posts first time.
