I think Scubaregs is still right, go into your idrive and make sure its set up right.Menacing said:Thank you![]()
It was more the ridged thing on top of the handle that doesnt work. I can't lock or unlock on the passenger side
Nanu said:I think Scubaregs is still right,
Feel free but save till it’s really neededScubaregs said:Nanu said:I think Scubaregs is still right,
You ok if I screenshot this Nanu, show it to my fiancée?
q96169we said:Easiest way to tell is to see whether passenger side door handle has touch sensitive locking zoon with those three or four lines, just as driver side handle.
If the handle is the same, then the car should have comfort access on both side. In this case, one thing you can try is to unlock and lock using driver side handle comfort access first. Then, try to use passenger side door handle comfort access and see whether it can then lock and unlock the car.
ori said:I had this on my previous e89 when it was just a few months old. It showed up as an error on Carly and requires a new door handle.
Do you have access to a code reader like Carly?
