Hi I have just brought a new set of coil overs stance + for my 2006 z4 coupe 3.0 si will I need short drop links ?
Newbers said:No. You'll be fine with OEM (at sensible ride height - not sure about if it's scraping the floor)
Newbers said:I fitted KW Variant 2's with everything else OEM (or Mehyle HD) and there is no problem at all. No clearance issues. ARB looks fine. I run a bit lower than Sport suspension but can still get over speed bumps.
I'd never heard of Stance+ but looking on their website they don't appear to do a Z4 version. Are you using kit for a 3 Series?
TempusFugit said:I have pretty much decided that BC BR will be the ones I go for, maybe in a couple of months time.
http://www.bc-racing.co.uk/applications/bmw-coilovers/bmw-z4-e85-02-08.html
DEL french said:Hi if your after a set of so called (budget coil overs) here is a link to venom motorsport they come with short drop links. £220 http://www.venommotorsport.com/suspension/stanceplus/street-coilovers/bmw-z4/
The Stance+ Street ride height adjustable Coilover suspension kits have been engineered and built to a very high standard. The units are made from Steel and powder coated Black to help weather protection. The kits are made exclusively for Stance+ and are meticulously inspected throughout the build process ensuring you get the very best quality suspension possible.
Each Coilover has been designed to ride firmer than the factory fitted suspension. The dampers are oil filled and are approximately 25%-30% stiffer, giving a firm yet forgiving ride quality. The springs are powder coated and the kits also benefits from built in bump stops, helper springs and shorter piston rods which also help provide a smoother ride. Each Stance+ Street Coilover kit is fully height adjustable by the millimetre. Our kits will lower from 30mm-80mm (most applications).
By fitting one of our Stance+ Street Coilover kits you will notice huge improvements in the handling and the on-road performance of your car. Not only will the car be lower but it will also handle a lot better than the standard O.E
ben g said:DEL french said:Hi if your after a set of so called (budget coil overs) here is a link to venom motorsport they come with short drop links. £220 http://www.venommotorsport.com/suspension/stanceplus/street-coilovers/bmw-z4/
They must surely be a huge pile of turd for £220?
DEL french said:Update
Stance + coil overs for my 2006 z4 coupe 3.0 si
Must surely be a huge pile of turd for £220?
In short yes they are!
I have removed these and fitted BC Racing coil overs, what a difference i should have fitted these in the first place.
DEL french said:The front strut dose not need to be dropped in order to adjust its a tight fit but i think there is just enough room.
BC supply shortened drop links 220mm in the kit.
hope this helps.
