enzed4 said:I think you've finally come to the crux of it. I didn't realise there was so much confusion over this option. My understanding, supported by what you mention above is:Silverstar said:Carista wrote back to me today and they are certain that the roof should go up with the remote, told me to fiddle around with some of the codings to do with enabling windows up when putting the roof up or something like. Will give it a go in a couple of days. They also have the coding to adjust the speed at which the roof goes up, again I'll try that in a couple of days and tell you what happens.
My understanding was as Tinker15 and Pbondar said that unless you had comfort access option 322 then none of this including folding mirrors would be possible but anyway if Carista can sort this then it will be huge plus for a lot of owners.
1. Opening the roof is no problem, you do not need 'comfort access'. It can be coded with Carly et al.
2. Closing the roof can either be done by 'comfort access' feature, or specifically option S322A (thanks pbondar), or with a Smarttop module. As far as I have seen, it can't be done by 3rd party software such as Carly, Carista etc.
If anyone can prove otherwise, please post and let us know what needs to be done to enable remote closing of the roof via the key fob.
Beeacon said:Funny, I was just looking into the Carista app today. Does it have any diagnostic capabilities too? Or is it purely for coding?
Pbondar said:I’m giving you 10 to 1 odds that Carly and Carista will never code your roof to close!![]()
Silverstar said:Pbondar said:I’m giving you 10 to 1 odds that Carly and Carista will never code your roof to close!![]()
I can't see any logical reason why, if it can code to close with the key, code to close the windows / mirrors with remote and code to close the roof at X MPH then I can't see why the roof can't close. But in any case if it doesn't happen I am not too bothered my main criteria was to close the windows and fold the mirrors which it has done BUT I thought if this can work it will help many others out without having to spend 200 or 300 on a SmartTop.
Pbondar said:Well people wouldn’t be well selling boxes for £300 if you could flick a s/w switch and get it done for nothing...my offer still stands!
I admire your selfless pursuit of the truth for the benefit of mankind...
When I was in product management in a dim and distant galaxy people like you were a curse we went to great lengths to defeat through obscurity, denial of information and any other obscurantism...
Carry on!
If I could find a smarttop for 2-300 I'd buy it today :lol:Silverstar said:Pbondar said:I’m giving you 10 to 1 odds that Carly and Carista will never code your roof to close!![]()
Chippie said:I bought a OBD K+Dcan cable with the ISTA, INPA,NCSExpert software, after initially having problems with a faulty lead, Last night i managed to set the mirrors to fold and windows to close on locking, as soon as I get chance I will post again with instructions on how to do the coding
Dub said:In case anyone comes across this again regarding the folding mirrors and Carly.
The 3 times I have seen or done this myself, the three options one in CAS and the others in the doors and windows ECU have to be done twice before it actually works, the non obvious option is the delay folding (mirrors) below the option in doors and windows I've found setting it to 0 is best.
So make the changes. Save to car. Start car. Stop car. Go back in and read from ecu. They may or may not be set correctly. If they aren't set them again, if they are, save to car again. And this time it will work.
Hold lock for slightly less than a second and they will close and then unlock they open instantly.
Hope this helps as I have seen others try once and it also hasn't worked, doing it a second time did.![]()
Chippie said:below is the procedure I used to code the folding mirrors, I think there are different versions of NCSexpert so some of the menus may be different
1. Launch NCS Expert software. Click “File” -> “Load profile” -> “Revtors Expert Profile”, then click OK.
2. Click the “VIN/ZCS/FA” Button (F1). Then “FA/ZCS/ECU”. Then choose your vehicle body type (E89)
3. Select “CAS” and click OK. ? it may take a while to process
4. Click “Back” (F6)
5. Click “process ECU”
6. Select module to work with (CAS, FRM,NFRM) and click OK
7. Click “Back”
8. Select module “CAS” and click ok
9. Click “change job” (F2) choose “CODIFRINDATEN_LESSEN”, then click ”execute job”
10. Next open file explorer and navigate to “Windows C > NCSExpert > work” folder and open “FSW_PSW.TRC “ file (open with notepad and “save as” “CAS_FSW_PSW.TRC” to a” backup “ folder you can create in the ” work” folder,( then close and reopen the original “FSW_PSW.TRC” file )
11. Next locate the text line you wish to alter (for folding mirrors when locking) FH_KOMFORTF_MIT_SUBST (use “file->edit->find” to locate ) and delete the “nicht” part of “nicht_aktiv” to just leave “aktiv”
12. Click “file->save as” and rename as “FSW_PSW.MAN “ click ok, click yes if prompted to replace it
13. Go back to NCS Expert and click “change Job” and select “SG_CODIEREN” click OK
14. Click “Execute job” this will then write to “CAS” module, the idrive will then close and reboot
15. To complete the programming For folding mirrors go back to stage 5 above and repeat the procedure for the “NFRM” module and find “ASP_EINKLAPPEN” and alter to “active” (saving a copy as “NFRM_PSW.TRC” , this gives you a copy of both modules you have altered in case you need to re set the original for any reason, simply “save as “,“FSW_PSW.MAN” back to the “work” folder and re run “SG_CODIEREN” )
16. If you wish to keep a backup every time you make a change then simply save a copy as “CAS1_FSW_PSW.TRC” “CAS2_FSW_PSW.TRC” “CAS3_FSW_PSW.TRC” etc. or whichever module you are working on.
CAS module close windows
KOMFORTSCHLIESSUNG_PA > active
KOMFORTSCHLIESSUNG_FB >active
I used NCSdummie for coding the windows and didn't really take note of what I altered but looking at the FSW_PSW file I can only think it is the above.
hope this is useful to someone.
please note you do this at your own risk.
