Coding an E85
Hagasan
Is there anyone near the Watford area or within a reasonable distance that can do this?
Looking to get the PDC switched on, mirror fold on (even though I don't think it'll work correctly), passenger window auto up/one touch and alarm chirping on locking/unlocking.
Pdc may be working but the chime could be unplugged, it's in the drivers side foot well, window probably just needs reprogramming which can be done from the switch, do o search on here
I'm actually retrofitting the PDC. As I've got a 2003 car the wiring is in place in the main loom. The gong pings when I go into reverse. Just plugged the module into the main loom then the sensor loom and sensors in the boot for now to test the sensors. Not getting anything at the sensors so think the feature is switched off. Car never came optioned with it..
Sure we can, can happily reset your windows and test sensors. Have got NCS so can code pretty much anything that is possible.
reset windows via switch one touch needs to be added in some cases,
TOUCH OPEN PASSENGER SIDE FH_BEIFAHRERTUER_TIPP_AUF
ONE TOUCH CLOSING PASSENGER WINDOW FH_FAHRERTUER_TIPP_ZU
PDC - Switching on signal can be done in SSS software.
