Codes
tabs
So i used the Creator C410 to put a new battery in.. Then decided to scan for codes.. Now im getting all these codes, Could be old codes but when i read each one it says No fault code ..
So if they are older codes how on earth do you get rid of them ? Even if i go back and click on clear code they still stay there.. Thanks muchly
Just clear all the codes..switch off everything ..lock the car..leave it for 30 mins, start car and plug in code reader…then ..voila…current codes..if any
Ive tried everything mate.. Its like 4 pages of these codes and they just wont bugger off.. i'll try your way.. Thanks for replying, means alot
You have to activate your ignition before you click on delete/clear/remove.
Locking and/or waiting is absolutely not required. With INPA it's done in one single second!
  • Like
Reactions: B21
