Its strange because when i go to read code the code says its not there.. There are 4 pages of old codes and they all say not there when i try to read them.. But the code reader just wont delete them.. Hope that makes senseMaybe the codes won’t reset for a reason?
What codes are you trying to reset?
Engine .. like 3 months ago had a misfire so changed the coils and misfire went away.. But its still showing as an old code.. Just really bugging me that they wont deleteWhich area? Engine/ chassis/airbag etc?
Hi.. no I go to read code.. nothing there, then delete code .. it says code deleted but it's notI’ve always been able to clear engine codes with my creator
Do they clear and come back? Or remain regardless
May be worth finding someone local with INPa or ista to see if that works before investing
I know.. it's ridiculousBizarre
I don't understand. If there isn't a code showing, how can you delete it? And then how do you know there is a code if it's not there?Hi.. no I go to read code.. nothing there, then delete code .. it says code deleted but it's not
Hi.. I hope these pics make more sense.. as you can see, there are 4 pages of codes, when i go to read codes they all say no fault code..I don't understand. If there isn't a code showing, how can you delete it? And then how do you know there is a code if it's not there?
I have a 410 and have had no problems clearing codes, although a couple have come straight back. But that's because the fault is still there.
Yes the option saying clear code is there,, But then says no code to clear.. The plot thickens. i know im not a super duper mechanic, but i know im not seeing thingsWhen you go to options can’t you clear them?
Just noticed this. The four pages are not codes, just four pages of 'modules' that the scanner is showing.There are 4 pages of old codes and they all say not there when i try to read them..
