Clutch / Gearbox Rattle
DPG
West Yorks
Got a bit of a rattle that I had a good chance to listen to today as I was sat in m62 traffic for an hour.
Basically, when I first start the car and its sat at idle I hear a helicopter type noise, as the car warms up it gets slightly louder.
The noise goes away completely when the clutch is pressed fully. (Could it be flywheel or gearbox)
Only really noticed it today as I didn't move for an hour and had my radio turned off.
Anyone else come across this?
Clutch noise on idle without the pedal being depressed has been mentioned here and is pretty normal, unless it gets REALLY loud. Sometimes it depends on temperature - mine is slightly audible only in cold weather. People have replaced clutches and flywheels, only to get the same sound after some miles. A search might help. The 350z is pretty much the same.
If you do a search it's a common problem with the si. I've had a new gear box, clutch and release bearing under warrenty and the noise was back withing a month after which the dealer decided it was normal and nothing to worry about :lol:
I noticed mine the day I picked the car up.
Mine only happens in neutral without the clutch being depressed.
Glad I'm not the only one. Cheers guys :thumbsup:
I'll still mention it to the dealer next time it's in.
Exactly the same ... Especially once warm and pulled into the drive after a journey. Also as mentioned ... My brother's old car - 350z did exactly the same with clutch released on idle. Hoping as documented that it is nothing to worry about (3.0 si)
Sent from my Galaxy Nexus using Tapatalk 2
I've got the same. Worse when car is hot. Thought it was the HVAs at first then noticed it not happening when clutch in.
Sounds horrible but apparently normal.
Wonder if thicker gear oil would dampen it down?
I have similar on my renault master ( oops is that a swear word on the forum ) garage said it is just the entry shaft chattering ? I hope so :wink:
Ok so as a bit of a thread re-awakening I took some videos of my 3.0Si Sport E86 and the noise we're talking about. There's a bit of an intro on the first one but the noise is quite quiet. It's more pronounced on the 2nd video, where you don't really need any talking over it.
I've spoken with a colleague at work who had DMF failure and he agreed that I should get it checked out, given his experience of what it sounds like. I'll probably be using Soper BMW as we're doing some work with them (IT related) at the moment and I'll see what they say.
Just a couple of points:
- Noise is after a 50 mile journey
- Noise occurs in neutral with clutch not depressed, also a very slight rattle when operating clutch normally (But no slippage felt)
- No loss of drive or power, as far as I can tell
- Car is a 58 plate (2008) UK model
- Current mileage is circa 43,000 miles
- Car is under BMW AUC Warranty, so if it does need work I'll have to see whether this is covered.
Video #1
[youtube]_fWPb-kglpU[/youtube]
Video #2
[youtube]Fg7FcZurODw[/youtube]
Are any of your cars similar to this? It's a little hard to judge noise through Youtube, but the volume of the problem for me is quite noticeable (When fans are turned off).
Mike G.
It's normal, don't worry about it and enjoy the car :) It's clutch related and if people are having brand new bits put on and it's back after a short time i wouldn't see the point in getting these costly bits replaced, even under warranty. For the record I've experienced it on numerous cars and never had a clutch failure.
It's not the gearbox. The helicopter-like noise is the flywheel, the rattle is clutch springs), and while driving during 1st to 2nd you can probably hear the input flange from the differential area (much further back, but sometimes confused with the former). If there is a rattle in the front when shifting, it's also the springs. These are common things on the Zed. I would not replace the clutch/flywheel unless the noise ceases to be the typical "clutch chatter" and becomes really loud. For your comfort, the 350z is very much the same, if not worse.
Mine sounds like that too.
It's booked in on Friday for an mechanic to have a quick look.
If he says its normal then I'll forget about it.
Mine sounds exactly like video #2. It is going in for a service tomorrow at Gilberts in Ealing tomorrow, but when I mentioned it to Adrian to book the car in he said that it is normal and due to the type of gearbox oil used which is a little thinner. He mentioned you could change the oil, but it will not fix it completely, but is completely normal.
Thanks for the replies to the videos guys, sounds like they were useful.
I can't help but obsess over this but with so many others reporting the same fault I think it can be safely ignored for now.
Mike.
Sent from my GT-I9300 using Tapatalk 2
Well the service manager and one of his tech's had a listen to mine and they reckon its either the release bearing or the flywheel.
Fly wheel is covered under warranty, release bearing isn't.
Best case scenario its the flywheel and replaced under warranty, worst case scenario its the bearing and I get a new clutch £600 lighter.
...........Or I can just ignore it
Video #1
Video #2
Mike G.
OT but you sound like pilot :thumbsup:
There is an excellent article on "gear rollover", as the phenomenon is called:
http://www.rsgear.com/articles/2008_08.pdf (especially page 2)
I haven't read a clearer and more logical explanation, so I wholeheartedly recommend it.
BMW E60, Focus, 350z and other cars equipped with the dual-mass flywheel are full of similar reports. Fortunately, a completely failed DMF sounds like a hammer knocking (many videos on youtube). Lightweight flywheels rattle more, as was the case with ZHP vs the regular 46. Replacing the flywheel/clutch has cured the problem in some Zed users' case, but we can be sure that sooner or later the noise will be back. I would not be a fan of using thicker gearbox oil - in winter it would make shifting even harder, especially with tired gear synchros.
