Clutch Fluid Resevoir
Oilcan
 Inverness, Scotland. UK
About to start my CDV delete and started by trying to locate the Clutch fluid reservoir however I am struggling to find it! Is anyone aware of it source of fluid? I am thinking it is gravity fed off the Brake Res as the OEM Clutch parts manual shows a feed hose but no reservoir. Please someone enlighten me, Zed is currently up on ramps with her knickers showing. '13 28i E89 btw
CDV delete completed. Easy job, good results. Topic closed.
The brake fluid reservoir is also the clutch reservoir.
I also changed out the rubber for braided hose, think it was about £20.
Thanks for the response flyb. I'm glad you confirmed my thought. I will look into a braided hose replacement if you reckon it is a worthwhile upgrade.
