Thrustyjust said:I wouldnt go solid. Its there for a reason and stops harmonic issues , so although more expensive , would stick with the DMF. You havent stated the mileage on the car and it might be the flywheel is OK . There is ways to measure it. Its not a massive faff to get the box out . Not like some FWD or 4wd cars, if you have the lift and tools.
simon1963 said:I’ve had a listen is morning. SMS ok from cold. When warm rattle/klonks in neutral clutch disengaged. If I engage the clutch only a very slight rattle. Fairly certain it’s dmf . Ca tech one doing Luk clutch kit and flywheel for £494.
Thrustyjust said:Mine does make a slight noise when out of gear and just idling and then goes quiet when I press the clutch pedal. Thought it might be the release bearing just glancing the pressure plate and spinning.
Its not enough of an issue to make me loose sleep . Just a slight change of sound.Mr Tidy said:Thrustyjust said:Mine does make a slight noise when out of gear and just idling and then goes quiet when I press the clutch pedal. Thought it might be the release bearing just glancing the pressure plate and spinning.
If those are the symptoms, it could just be a release bearing.
Last time I had that issue it was on a Sierra Sapphire (I'm old OK) but by the time the gearbox was off it seemed daft not to have a new clutch as well. (No DMF on them thankfully)!
mjennings23 said:Clutch and flywheel under £400 from autodoc last time I checked, both LUK parts
Darkangelv2 said:mjennings23 wrote: ↑Wed Jun 05, 2019 4:04 pm
Have you used them? The reviews look shocking?
