tobysvjones1
New member
Hi
I have an 08 2.5 SE SI with a slipping clutch. An indy specialist said that they will charge £250 labour if I supply the clutch and flywheel (as I can find them a couple of hundred pound cheaper on mister-auto than what they can source).
The garage has said that I need a 228mm diameter clutch with OEM number 21207587368, however Mister-auto only has 230mm clutches that match that OEM number.
I know I have read on here before that a 230mm clutch would be ok, but that was for a 3.0 z4.
Any help would be much appreciated.
thanks.
thanks.
