The first thing I did when I got my car was pull the rubber bungs of the drains and give them a clean out by sticking some flexible cable up there. The drivers side one ran clear but the passenger side one only got a slow dribble. Most of the water seems to come out the jacking points along the sills. Not so good. So tonight I moved the passenger seat forward and reached over to feel where the motor housing was. I then got a long cable tie with some masking tape on it and stuck it down the side of the motor in to the tray. It came out wet. I then thought what do I have that sucks? A hand vacuum brake bleeder thing! I stuck that down the side of the motor and sucked out about 400ml of water. It seems I defo have a blocked drain. I then moved on to a Pela 6000 oil extractor which has a thinner pipe and managed to suck out a tiny bit more. I then used the Pela to stick up the drain from the bottom to see if I could suck any rubbish out but all I got was a bit of a gurgle. It was like there was a tiny bit of moisture up there but certainly not a lot.
I wish I could see what was going on down there. I might have to invest in one of those little boroscope camera thingys. Is the drain hole at the very lowest point of the tray? It's a facelift car if it makes any difference.
