Ok - finished. A few things:
1. Dont try to mix lenses. Keep the lenses from your existing lights and use those. I tried to use a fresh pair from the donor units, as my existing lense wasn't in the best condition. However, by using a different lense, the fit wasnt the greatest, and sealing the units was tricky.
2. I had various problems, which added a few hours to the job. One of the bolts for fitting the headlight to the car seized, so I had a mission to drill the screw out, as the torque head sheared off
If you are doing this, be prepared for niggles which will delay your work. Also, do a dry run to ensure you have all the right tools! I did, but that was luck, not judgement :lol:
3. I had an accident with my Angel Eyes
Dropped one of the rings in some water, and despite drying them out, they wouldnt light up
A costly mistake. I may buy another set in the future, but was happy enough with the clear light conversion.
4. I am not handy with tools. I thought I would make a hash of it. I can say for certain that this job is not difficult, but is time consuming.
Anyway.....
Before:
After
