One of my headlights has got a film of grime on the inside which appears to have been caused by a perished seal at the back.
I know Z4 light clusters are notoriously fiddly but i'm able to remove it from the car.
The main thing i need to know is if its possible to remove the motor/other perishable electronics? That way i could just fill the whole thing up with fairy liquid and blast it out after a soak. If not then some keyhole surgery will be required, what would people suggest, perhaps a big bendy pipe cleaner?
If you look at the car directly from the front you can see that ones a different colour than the other due to the dirt, not good!
Many thanks
Many thanks
