Cleaned up and Painted my Rotors/Calipers.
Shipkiller
Veteran
Did this this weekend...
If you're interested you can add these: http://www.vinzdecals.com/createcaliper.html
Here's a link ith some pix: http://bimmer.roadfly.com/bmw/forums/z3/8915337-1.html
Really good. :thumbsup:
Did this myself last year and it makes such a difference compared to the scabby standard mix of rust and dust.
Did you use one of those Caliper paint kits that are offered or just get a can of paint? 8)
Zeta, thanks for the links. I had been thinking of something like that... but just a plain old "BMW"
Wazzz, I went to 'AdvanceAuto and bought a can of Duplicolor 'Black' caliper paint for the rotors, and a Dupicolor "Red" caliper kit to do the calipers. The kit contains a spray can of cleaner (you need another can just to make sure...), a brush ( you need several more of these), and a can of paint..
You will also need a small soft wire brush and lots of rags.
The paint has some special stuff in it (some type of ceramic) to allow the paint to withstand 500'.
I took the brake pads out and reattached the floating caliper to allow for cleaning, then cleaned again, then cleaned again. Did I say clean the calipers?
Then got out my bushes and started to paint. The paint dries very quickly...
After about four hours I put the brake pads back in and about two hours after that, I was driving the car, but being easy on the brakes. I just wanted them somewhat hot, just to bake on the paint.
Did the rear brakes the next day...
I'm recoating the hat area of the rotor with bright Zinc coating. It won't mind getting scorched by my spirited track driving. Pics to follow this weekend.
Shipkiller....nice job indeed!
Thanks for the info Shipkiller. :) I think that is one of the best mods you have done. :) I am going to do it but I think at the same time I change pads and rotors which is coming soon. Thanks again for info. :thumbsup:
