pvr said:Does the mitt not need normal lube like you use for a bar?
Marlon said:pvr said:Does the mitt not need normal lube like you use for a bar?
Apparently not - it works with normal car shampoo (although I've read that some owners use the lube with it)
Is that a thumbs up then Marlon? If so I'll be off to halfords tomorrow on yours and Robs say so, so no pressure :wink:Marlon said:Well I used it this evening and I'm very happy with the results. The paintwork felt noticeably smother and after a polish looks glossy and wet![]()
Pastry said:Is that a thumbs up then Marlon? If so I'll be off to halfords tomorrow on yours and Robs say so, so no pressure :wink:Marlon said:Well I used it this evening and I'm very happy with the results. The paintwork felt noticeably smother and after a polish looks glossy and wet![]()
Taz said:lol yes i meant a bar
I would take up that challenge Mr Bear however they are harvesting wheat all around us do everything is covered in half inch of dust! Oh and I'm afraid to rub the roof too hard in case all the paint falls offSmartbear said:Very clean & shiny Marlon 8)
That pastry fellow has his work cut out to better that![]()
Ducklakeview said:I got a clay cloth from these guys; http://www.theclayclothcompany.co.uk/ourshop/prod_4196009-A-Clay-Cloth-Sovereign.html
It's excellent, and supposedly very long lasting..
Mike
Pastry said:I would take up that challenge Mr Bear however they are harvesting wheat all around us do everything is covered in half inch of dust! Oh and I'm afraid to rub the roof too hard in case all the paint falls offSmartbear said:Very clean & shiny Marlon 8)
Rob![]()
Used the same one for the first time last weekend and followed the advice from the boy in the shop and used it as a sponge with the normal good quality shampoo instead of a specialist lubricant and worked great. Was told you can use it b/w 30 - 50 times but how true that is only time will tellMarlon said:Off to buy a Farecla G3 Body Prep Clay Mitt from Halfords - gets great reviews
http://www.halfords.com/motoring/car-cleaning/clay-bars-detailing-products/farecla-g3-body-prep-clay-mitt
Marlon said:Looking good Baza![]()
