Thank you Pondrew, that is what I wanted to know, simple explanationPondrew said:As said earlier by someone, it will be DC output. Chip LEDs don't work properly with AC, as they flicker.
As said, look for a 30 (ish) volt, 18 watt or higher, or 0.6 amp or higher.
As long as the voltage is around the same and the wattage/ amperage of the tranny is a minimum of what you have, it doesn't matter if it is rated higher. The 18 watts/ 0.6 amp is the power consumption of your lights, not the tranny.
