I have suffered these lights twice, apart from the low coolant indicator. They were both ABS wheel speed sensor. But to be sure the codes need to be read.
If the handbrake light stays on yellow swith the handbrake off, then I would also say ABS sensor. You need a decent code reader to tell you which one.
Check the coolant level in the expansion tank too.
That could be a leak, a failed sensor, or a jammed float in the tank (it is separate from the one with the red indicator rod on it)
However, if all these lights came on at once it could also be due to a weak battery.
