Hi All, a while back i had a full hunter alignment and 2 new goodyears on the back done, the zed was transformed
However, every 8 or 9 days i would have to fill the O/S rear with about 15lbs of air (low tyre pressure light on the dash)
So, thinkin it was probably a faulty valve i took it back. The lads at Walkers in leicester whipped the wheel off and tested it, yep a faulty valve so replaced it. After sorting that they tested it again, and found a 4" hairline crack in the centre of the alloy allowing air to escape
As money is quite tight at the minute i cant afford to replace my alloys (as much as i would like to, MV2's are my choice) i was a bit worried to say the least i needed the zed to get home.
The boss had a look and pondered on what to do "CHEMICAL METAL" he said, that should sort it for now. So straight on the phone and ordered some and to my surprise it turned up 5 mins later
He applied it straight away, made me a coffee and said to wait. After about 40 mins the lads pumped the tyre back up and, NO LEAKS! Back on the zed and ready to go and NO CHARGE!
What do you think guys, will this hold out ok untill i can afford some new alloys or should i be worried
Thanks for reading, Cheers. tug
