Few days after one year of faultless ownership I've got some codes, hoping its a sensor which I can fit myself but not certain.
Code P2198 O2 Sensor Signal Biased/Stuck Rich (Bank 2 Sensor 1)
Code P114d?
In DIS I get:
a lot of "fault not currently present" which I don't understand.
For the first it tells me to check the lines and plug connections on lambda before cat bank 2 and if the fault isn't rectified to replace the sensor.
On the second fault it tells me: voltage outside tolerance range. Wiring defective, leak in exhaust system, oxygen sensors (bank 2) defective.
For the air pump it lists all these possible causes for the fault:
Air pump relay defective, air pump defective, air valve does not fully open, restriction in intake hose, leak in secondary air system.
The air pump starts up fine I'm wondering if the valve could be defective and leaking air into the system?
Would fitting a new lambda be the first thing to do? Reading pHilli0's recent thread, same code (P114d) which turned out to be a leak in the exhaust which has made me reluctant to throw money on a sensor straight away.
Does the live data point to anything specific? https://www.youtube.com/watch?v=lW4-0X6ylLs
Thanks in advance!
Code P114d?
In DIS I get:
Thanks in advance!
