Check Engine and severe judder at idle
PJR
Was driving home last night in my 2012 28i auto, and came to a set of lights where opportunity arose to set off briskly on green.
After flooring the pedal (in Sport Mode) the car moved off fine, but then something went a wry. The Check Engine light came on, with a warning that power was restricted and to drive modestly, and take it for service. At the next set of lights while in the queue the car had a really quite severe judder to it.
What’s the likely prognosis... is it plugs/coils (?) or something more grave?
You need fault codes to avoid throwing unnecessary parts at the car.
It’s probably a plug/coil issue..when these happen the ECU disables that cylinder making the engine feel terrible plus warning lights etc..
Those faults reset themselves on next start up until it happens again.
As SmartBear says first port of call is a decent code reader.. :thumbsup:
I had this issue after putting the Dinan map on my car. I bought a Carly to analyze and it was spitting out a cylinder 6 problem. After advise from this site, I put in new plugs ($200) and haven't had a single issue since.
Having similar issue. Has happened 3 times now.
After stopping emgine & restarting everything seems fine.
Carly throws up a Cylinder 4 problem.
Will start with spark plug replacements.
They should have been changed last October. But better me doing it myself for peace of mind.
Any idea what brand BMW uses or which do you guys suggest?
Instead of changing relatively new plugs try swapping them around to see if the fault moves with the plug. That would prove it’s the plug.
Could save the cost of 6 plugs :?
Boy speaks a lot of sense..FWIW I bet its a coil!
True.
If that last service report is to be believed the plugs should be fine.
I will start by swapping the coil first and see if the problem manifests itself on the swapped cylinder then go from there.
The plugs aren't an expense, relatively. But boy are those ignition coils expensive. Didn't know they are a common failure point until i asked and googled.
thanks
True.
thanks
Last time I looked NGK coils were just over £20
Thanks for all the info folks- super helpful as always on here!
So two further questions...
Will a £25 code reader from amazon do the trick or is there a smarter option to buy, eg is a Carly worth seeking out?
If it is a plug or a coil, are these serviceable by a complete and utter mechanical clutz (ie me) or better take to a garage?
Plugs & coils are entirely doable on your own.
The coil just requires pulling up on a plastic cap, pulling out the wiring and then tugging on the coil to remove.
You will have to remove plastic engine cover first.
The plugs can be easy or difficult depending on if they are stuck and won't turn. In that case it's worth spraying some penetrant spray and waiting an hour or so. You certainly don't want to break the plug.
Here's an explainer video:
https://youtu.be/-Vyap3DkW-E
On the code reader - it depends.
I have a Creador C110 which I got initially for my 3 Series. It's about £48 on Amazon.
Since then I got the Carly. It not only does diagnostics but also allows you to code certain features.
The one downside is that it is based on an annual subscription.
Out of interest, when you experienced the problem, were you low on fuel? I.e had the fuel warning message come on?
Thanks Wanderer, that’s great.
No, the fuel light wasn’t on as far as I recall.
I have taken a punt on a cheap reader so I could get it delivered today, so I’ll see how I get on, thought it was worth a punt for the money.
If it is the plugs, is it better to change them all at once or just change the faulty one (s),,?
If one plug has gone then the others will not be far behind..ditto on coils..
Did you get the codes read?
As an update, On mine i had a Cylinder 4 misfire error code as well as a low fuel tank warning error.
I noticed that on two occasions this happened at the exact same area, at a roundabout near me.
I did go down the path of thinking that it was exactly like other people who have had BMW problems whilst taking a hard right turn (e.g. around a roundabout). The theory is that if the tank is relatively low on fuel (1/8th to 1/4) then as you take a hard right the fuel moves to the left of the tank leaving the fuel pump exposed on the right.
At that stage the pump:
- is not being cooled properly by the fuel
- is not able to provide the proper foot pound of pressure and
- is possibly liable to suck up sediment
Hence causing the car to go into limp mode.
Now, at those times the car had 1/4 tank of fuel, which is fine in my mind for any car.
So i went into my local parts store and picked up a Bosch ignition coil (€40). That's generally the price here in Ireland, even online.
Swapped it out and actually heard it misfiring on startup.
Now, the problem with Coil #4 is that it is in an awkward place so i wasn't sure if it was properly in place, so i gave it a few good taps. Still misfired.
Then noticed that the electrical connector plug was not going all the way in to meet the reciprocal lip. So i pushed that in further, locked it in and she started up fine.
Being such a nice sunny afternoon, we went for a drive.
90KM's in total up the coast and back, through motorways, narrow winding roads and a good few roundabouts.
No problems. All back to mormal.
A few things to note though:
1) The Bosch Ignition Coil that my motor parts store sold me was the exact same code as the one removed - Good sign +++
2) The Ignition Coil removed had a date of 06 May 2010 - so was never changed since the car was built! - ~90,000KMs / ~56,000Miles
3) The removed coil had it's rubber coating removed in one spot and at a second spot it is only held on at one side of the circle. Considering what these things do, i doubt it's a good idea to have exposed metal.
So, yes, it was the coil.
Just go figure out which one it is and change it, if you can.
It could have also been the spark plug ... or the injector.
Injectors are rarer as failure items on N20 engines…coils n plugs often misbehave especially after a remap as that’s when more energy is required to ignite the fuel… :thumbsup:
Nice simple result..
Good tip!
Hi, took a week to find the time to plug in the reader, but I now have the codes:
P0304, cylinder 4 misfire
P0136, O2 sensor circuit bank 1 sensor 2
Took the car around the block and along the bypass for a couple of miles and it seemed to be running ok, the engine light is gone (as previous poster said it would be).
Does this seem like plugs/coils or something else?
Is it safe (and reliable) to drive or better sorted ASAP?
