Afternoon all,
I live in an old drafty house and there are thousands of jobs ahead. These jobs may include new windows (currently old single glazed), general insulation, potentially underfloor void insulation (but I'm guessing this isnt possible due to damp rising issues) and a few other things to keep the heat in.
So far I have done the cavity walls, put insulation in the roof, and one of my rooms has 100mm of rockwool for internal insulation (on top of the cavity on the external wall).
The boiler is pretty good, but the pipes and radiators are very old, and may need redoing in the next 5 years or so. The hot pipes are uninsulated and go under the floor boards into the air voids (which really helps out!).
Now you know my background, I'm thinking about getting some form of thermal imaging camera. This will enable me to see where the house is leaking heat. Also, would be interesting to see if the wall with 100mm of rockwool is 'cooler' on the outside. Also, I'm interested in using it over time to see how new potential upgrades help. Other interesting uses could be: Checking radiators for hot / cold spots, which external windows leak the most heat, areas in roof, flooring heat loss (carpet vs bare wood).
Anyhow, I was wondering if anyone has bought a cheap one by any chance? I see there is the 'flir one thermal imaging camera' but I'm not sure if my phone will support it, as it tends to be a little tricky.
Thoughts welcome.
Best,
Theo
Thoughts welcome.
Best,
Theo
