Charging System Failure
seanrw
New member
Just wondering if anybody can shed any light on a slight issue I'm having with my 2004 E85 Z4 3.0. I've tried going through the forums etc. and I cannot find anything helpful. I'll try keep this brief:
So I'm driving and suddenly the dashboard lit up like a christmas tree (proper bm :rofl: ) so I decided to turn back home; I noticed the steering was heavy and the electrical system failing - common alternator failure from experience. A test with a multimeter suggested a faulty alternator as the battery was getting less than 12v. I replaced the alternator and test drove for 30 miles and all seemed ok. Then the next morning the exact same problem returned, dashboard lights etc.
After a lot of head scratching I decided to replace the alternator AGAIN, except the battery is getting less than 12v once started. I have tried an alternative battery to double check but still getting 12v. If I test the live terminal on the alternator its getting around 14v.
So my question is:
If I have a WORKING alternator and battery, why is it not charging? It's as though there's a break in the circuit from the alternator to the battery.
Many thanks in advance!
I think the Z4 has an intelligent alternator as there is an extra cable to it. I think that this may be not " telling " the alternator to charge the battery , and so the alternator / regulator is not sending charge to the battery. Don't take this as gospel, please investigate it yourself, but I would get the alternator checked out , as most alternator repair shops will be able to bypass this signal from the car.
Dit you get your problem fixed .....the extra wire going to alternator is the obd2 port wire. With my problem i had a long search regarding problems look like most z4 has the same :headbang: problems. :headbang: . Alternator not charging . Starter clicking and battery bad , when you test all of these,
