Change your Gearbox Oil !
Ah I see, so feels like a better shift instead of actually physically functioning better. You got any links for the redline? :)
Just search Redline MTL on eBay, 2 quarts needed. If you're unsure you can mix MTL with the recommended oil but I didn't bother.
For my 2004 3.0 manual gearbox I changed to 50/50 mix of Redline MTF and Redline ATF 4 as recommended by forums and OPIE oils. You'll need to buy 1 quart of each. It did improve the shift.
Is this as simple as draining and refilling, or do people take the casing apart and change the filter too? Not sure if this is applicable to manual, just watched a video of an auto change online and they took the filter out as well as flushed the torque converter.
I assume with manual it's a lot simpler job?
Its just a drain and refill on the manual, there's no filter to change. There's not even a flush you can add prior to draining, like you can with engine oil if memory serves. If yours is an auto I would be doing a filter change, filter kits usually work out a bit cheaper in this respect.
