Hi,
I rang a quick fit tyre place this morning as i have a slow leak in my driver side rear tyre... every time i pump it back up the light comes on the dash 2 weeks later...
The guy on the phone told me that if there is a puncture in a run flat then i would need to replace the tyre... that is fine but i told him i was going to change from run flats and he then said:
"The only problem is... if you change to non run flats on the Z4, you have to change the whole suspension"... is he right... i never changed the suspension when i had non run flats before, thanks in advance
