Change of stereo
The stereo in my recently purchased 2006 E85 2.5 is knackered.
I want CarPlay and the ability for satnav, etc.
Any suggestions please? Every time I do a google search, the only viable option is single din. I’m unsure why vast majority advertise the ones that sit on the dash board as suitable, or the case you have to cut a hole? IMG_0206.png
The first question to clarify is what type of hi-fi system your car has as standard. 6 speakers (the easiest to replace), 10 speakers, without DSP (can be replaced at home with a little expertise), with DSP, 10 speakers (the most difficult to replace/requires a lot of things to replace it).
Hi @Sherminator, I've had my Z4M E86 since the start of the year and I did the same investigations you have no doubt started. I wanted to add GPS and DAB+ to the car without having to go through the phone.
[Edit: Apologies, after writing I realised this was a bit of a brain dump]
As @feket663 mentions the first important question is exactly what stereo system you have in the car because the fancier it is the more fiddly it is to change. You can find this out by going to an excellent site owned by forum member @tonyz4c which can detail all the options on any given car. If you put your vin number in and click on the matching line it will show a window with all your options. (You can narrow it down by selecting some of the drop downs, e.g. i always select the area on the map then the zone, model and colour). I have the "S662A Radio BMW Business CD" with no extra speaker options which is the simplest setup. There are some good postings in the forum about working with the various stereo setups.
When it comes to what options are available there are several that I considered.
Next question is proprietory head unit (Alpine, Pioneer etc) or Android. Proprietory means company specific software but everything should work out of the box, Android head unit means there might be some configuring needed but once working it will behave like any other android tablet and you can install any app from the google play store and it should work.
So options, first if you have and want to make use of a flip-up screen area of the dashboard:
1. If your car has the flip-screen in the dashboard then you could replace this with an android head unit. Before I bought my car I was looking for one with the flip-up screen as this was my plan. I started talking with the people at hifimax.net about options. Their tech support was excellent and responded to my endless email questions very promptly and politely. For our E85/E86 models it would be one of these Android head units. These are fixed screens so would no longer flip up and down. I cant speak to the final quality as I ended up getting a car without the original flip-up screen and so going a different route.
2. If your car does not have the flip-up screen it is still possible to go with the hifimax option but you would have to cut a whole in the dash. They provide templates and instructions for doing so.
3. It is technically possible to install a homemade solution. @danmiddle2 wrote up an excellent how to guide explaining how he replaced the standard flip-up screen with his own custom build using a standard android tablet. This clever approach has the added benefit of the new screen still using the flip-up mechanism.
If you dont have the flip-up screen or dont want to use that part (for example some people have removed the flip-up screen and just turned that area into a little storage area) then there are a couple of other options using the 1 DIN slot that originally houses the stereo head unit.
4. 1 DIN stereo with fixed screen. There are head units out there which have a main body with a 1 DIN sizing and a fixed flat screen on the outside such as this. A quick search of the web will find web pages like this showing a few examples. Some have quite small screens because of the single DIN form factor, some have large screens that stick forward. On some the screens are removable if you wanted to hide the screen in the glovebox when you leave the car. Some of the screens are nice and large so easy to use but some might consider a downside that the air blowers cannot blow into your face as the screen would be in the way (there would still be air flow just not directly at you)
5. Lastly (and this is the option I went for) there are 1 DIN head units which have a slide-out screen. This means the screen can retract back into the head unit when the engine is off. The screens aren't as large as those on the fixed screen units as they obviously have to fit inside the 1 DIN body but they are usually 7". There are a few proprietary models such as the pioneer or there are android variants (there are a whole bunch of android flip-out head units to choose from).
After all this investigation I ended up choosing to go the Android flip-out screen route. To give you some idea of what was involved, in my case I went for an Erisin unit. Erisin seemed to have a bunch of variants and this was just the tartiest one :) I also bought their DAB dongle (most android head units need a separate DAB dongle that connects via USB, there are many makes of DAB dongle and they should all work).
I have installed the head unit and most features like GPS worked straight away. I am still working on connecting up the antenna for the DAB dongle so dont have DAB yet. However it supports both Apple Carplay and Android Auto. I have already connected it to the house wifi and downloaded a new GPS app (Magic Earth, which I prefer over Google Maps) and the Brave web browser via the Play store and searching the web works too. This unit also came with a connection for a mobile phone SIM so if I wanted I could install a SIM card and the car would have full mobile signal whenever there was phone coverage without needing my mobile. It has connections in the back for a reversing camera which is something I plan to install in the future. When I get everything working how I like it I will probably make a posting in the how to section with photos in case it helps anyone in the future.
I hope some of this waffle was of use to you.
Won't directly solve your problem, but assuming you can find a replacement business radio head unit (should be easy) and install a cheap bluetooth adapter (Bluemusic is what I use for instance), the following might be an option.
I recently installed a CarpodGo T3 Pro screen in my car. See link: https://z4-forum.com/threads/what-have-you-done-to-your-car-today.93757/post-2136516
I looked at various options for adding CarPlay to my car, but found that the aftermarket units are usually relatively expensive, and require changing the fascia of the radio, which I didn't want to do. My install is fully removable, works like a charm, and I actually like the spot it's in as well. No issues with the vents being blocked either, as they're really not.
This is my solution. I install a cheap, chinese Android unit ("Ossuret" Brand with 8 core CPU and 4+64 GB for approxx 150 USD from Aliexpress's EU Warehouse in Poland, I'm living in Hungary) in 3D printed frame, place of original display. I have S676 10 speaker Hifi system, without DSP, I connected Android HU output to CD changer input of original radio (The IBUS, GND and +12 V wire Leave connected to the CD Changer, otherwise, there will be no CD CHANGER menu item on the original radio. The sound quality similar to original CD, totally acceptable for me. I can run WAZE or Google Maps, and all of android applications. I bought a cheap wired, chinese steering wheel control joystick, and can control the android unit. It has been working perfectly for 1.5 years, even during occasional 10-12 hour drives.
Thanks all. Very appreciated on the write ups.
I popped into a local shop to me.
-Quote £320 for basic swap out for a Kenwood.
-CarPlay Pioneer, £1k (full screen)
The biggest rip off from someone off Facebook market; £650 supply and fit for a unit sitting on the dashboard! Not even a branded nd he said his charge was £100 and the unbranded unit is £550, citing it was 16gb.
