Angelus666 said:
No one with a very expensive classic car would ceramic coat it.
That doesn't make any sense to me.. Many do.. How many car decisions do owners of classics or prestige cars
really make with a voice of ''oh but if I drive it into a wall/trolley/bollard then....'' (and even in that case it can be remedied by expanding the area that your sanding / machining locally and an inexpensive touch up with the coating..)
Angelus666 said:
I think people look at ceramic coating in the wrong way.....surely these are better used for a daily driver that you just want to keep mostly clean. The industry has fooled everyone into thinking your paintwork needs 20 hours of machine polishing before you apply it....what a load of rubbish.
If you love your car, enjoy the ownership process and will weekly wash by hand and care for it then it makes more sense to use waxes and glazes. You can strip these of, try a different product and keep your costs much lower....and if you get a scratch or ding, you'll probably want to sort that asap. You'll then need to firstly strip the coating to ensure consistency of finish and then spend loads reapplying the coating. No one with a very expensive classic car would ceramic coat it.
However, if you only want your car to be clean as quickly as possible so it's presentable (and not bothered by scratches of dings) then it makes much more sense to apply a ceramic coating. Am I wrong...?
It's all relative.. Do you need extensive polishing to apply a coating? No..
Does a quick polish and decontamination help? certainly does.
Is the result from A going to be better than B? Certainly will.
Where you draw the line depends very much on your car, what it is to you, how old it is, how you'll use it and so on..
If you want it for ease of cleaning, then you're probably not bothered if it has a few scratches - and you probably don't need to spend on a high performing treatment anyway.
If you're the type who wants it coated so it always looks fresh, then having all of the defects remedied before coating is a no-brainer. I've held off doing some of my cars for this exact reason - I don't have the time to do it right at the moment..
It makes as much sense for an expensive car as it does a daily driver, how much you spend in the process is the difference between the two.. horses for courses..
