GrinnyGrl said:Hi, can anyone recommend a ceramic coating specialist in the Bury st Edmunds area?
Also how long does it take normally?
Tia
Dawn
Jollygiant said:GrinnyGrl said:Hi, can anyone recommend a ceramic coating specialist in the Bury st Edmunds area?
Tia
Dawn
Buy a Gtechniq or Autoglym kit and do it yourself for at least 1/4 of the price.
Just make sure you do it after using a clay mit and good few coats of polish.
tweeky687 said:Jollygiant said:Buy a Gtechniq or Autoglym kit and do it yourself for at least 1/4 of the price.
Not great advise, you need to do a proper decontamination wash and then a stage 1 machine polish then washed again to get the paint ready for the ppf or ceramic coating.
Jollygiant said:You don't HAVE to do a stage 1 polish as clay bar/ mitting it is good enough.
tomscott said:Depends on your expectations. To me as awesome as ceramic coating is I think the hybrid ceramic waxes are better and much much cheaper for older cars but require more maintenance.
From a ppf perspective, the cost of it is high, again depends if the car is a pcp, lease or do you own it or will you own it. If the latter deffo if not, I wouldn't bother, a lot of money to protect the car for someone else.
q96169we said:Sorry, but I have to say it's definitely not a good idea. Clay bar/mit will introduce huge amount of marring if not swril which at least need the finish stage of polish to sort out before any coating being applied if you want the good outcome.
Then, depending on which Gtechniq product you referred to, their CSL product can be difficult to apply if the env is not well controlled. If you referred to those spary-on wash-off/wipe off type product (as you also put AutoGlym next to Gtechniq), then it's just a spary sealent with minimum amount of silica material which isn't ceramic coating.
I did ceramic coating to my Z4 myself using Gyeon's evo line (specifically, mohs evo with cancoat on top). Before the coating, I did full wash, decon, followed by single stage machine polishing then pannel wipe twice. It's done over Aug bank holiday weekend in 2021 after I picked up the car so it's about 3 days of work if DIY. After going through the whole process of what a pro detailer will do for new car ceramic coating, I would say their quote of about £1k for Z4 isn't too much. Therefore, either don't do it at all and just use some spary wax/sealent, or do it properly (regardless of DIY or find a pro to do it)
GrinnyGrl said:Calm down boys. It's only a car!![]()
Thanks for all the tips tho.
Jollygiant said:q96169we said:Sorry, but I have to say it's definitely not a good idea. Clay bar/mit will introduce huge amount of marring if not swril which at least need the finish stage of polish to sort out before any coating being applied if you want the good outcome.
Like I said you do you and I'll do me.
Enjoy your 5k hydrophobicness when it rains and I'll enjoy my £70 one.
