That would be recommended, yesSpaniarduk said:I have a question to add.
Is it possible to use a tube clamp or similar at any point along the line to limit or avoid the fluid to leak out while you're doing it?
Ideally yes, there will always be some fluid loss (either from the hose side or from the slave cylinder side).Cribert said:Can someone confirm if I will need to bleed the system if clamping the hose?
