CDV removed!
Lance
Northants
DISA out and cleaned last week, CDV removed this morning. Pretty easy to do, gaining access is the most aggro.
Made the mistake of not clamping the hose, pissed fluid, requiring a clutch bleed, but easy to do and took 5 mins.
I think it was hotride that suggested loosening the small nut first (it's 11mm), this is definitely the best method.
Not driven it yet, but will report back once I have.
Yep a definite improvement, not huge but much smoother changes. Not smoothed out the slotting of the lever between gears, just engagement of the gears when letting the clutch out.
CDV will have no effect on the actual movement of the gear lever, just the engagement of the gears when lifting foot from the clutch.
