CDV Removal @ my place on Sat 9/20
ZetaTre
 San Diego County
Hopefully by this coming up Saturday (September 20th 2008) I will receive the modified Clutch Delay
Valve for the Z4 so I will replace it.
More information can be found on this website:
From Zechhausen website:
The Clutch Delay Valve (CDV) is a one-way restrictor installed by the factory between the clutch slave cylinder and clutch master cylinder. It "delays" the engagement of the clutch, much like old record players used a damped tone-arm to gently lower the needle onto the surface of a record. Because of this valve, no matter how quickly you lift your foot off the clutch pedal, the clutch engages the flywheel at a constant (slow) rate. In theory, it can save the driveline from shock, were an inexperienced (or immature) driver to dump the clutch at high RPM. But in practice, all it does is prematurely wear out the clutch and turn experienced drivers into people who, despite 20 years of practice, cannot shift gears smoothly. During parallel parking maneuvers, the delay can be infuriating, causing constant clutch slippage. And during hard acceleration, the large amount of clutch slippage can greatly shorten the life of your clutch. During normal, sedate driving, the shift from first into second gear is often jerky, leading passengers to question your skill. As the driver, you can see your passengers' heads bobbing back and forth during every shift! Yes, in their minds, they are laughing at you.
This mod applies only to the following Zs with manual transmission:
Z3 2.5i, 3.0i (1999-2002)
Z4 2.5i, 3.0i, 3.0si (2003-2008)
I will confirm/cancel this during the week depending on weather I get the part or not.
Everyone is invited... And of course we'll have some Italian food on the menu. I'm thinking lasagne
Valve for the Z4 so I will replace it. I will confirm/cancel this during the week depending on weather I get the part or not.
So Zeta Tre, is this still happening or is it a no-go?
Valve came in today, so I'm all up and running.
Just gotta go pick up a vacuum pump, a couple wrenches I'm missing and some BMW break fluid.
Anyway, I'm gonna have lasagne ready for Noon and get I'm gonna start working on this around 1PM.
See ya!!!!!!!
We pretty much got everything... So I'm not really sure what you guys could bring... I'm not even that sure how many folks are gonne be here so...
I would say just not to warry about it...
Zetatre, Had a great time, thanks for the invite. It's always fun supervising someone else while they're working on their car. :poke: When I get a chance to do the project we talked about, I'll let you and Bob know.
Had a great time today. Nice to see everyone and getting to meet Mike, I will try to get some info on the rims and the intake on Monday and will report my findings.
I always love watching some else work. I get tired just watching.
JoAnna thanks for the pics from the HC trip. I will return you memory stick in October at the Big Bear event. After tonight the stick will be in the car just on the off chance we see you before.
Thank you for lunch it was awesome as per normal. Mary is a great cook. :poke:
Thanks Mary and Luca for a great day! Took lots of pics of the CDV removal! Good to meet up with such great friends and meet new friends too!
Agree with Bob, is was a great lunch and Mary is a great cook! :D
Bob:PLEASE put your pics on the memory stick before you return it to me. OK to delete what is there, they are on my laptop!
Bob looks like we will be headed that way for Vicke's class reunion. Do you know of a good route from indiana. If so pm me Thanks
You have a PM sir. I did have a few questions, however. :driving:
Thanks y'all 4 coming!!!! I hope you had a good day. I'm looking forward for someone to update pix of my "working suit"... ehehhe!!!
Btw, I'm pretty impressed by the difference that little CDV made. I believe Mary is also enjoying the car a lot more... Hopefully it'll be a little less of a garage queen...
IS THAT A HINT FOR PICS? I HAVE LOTS OF PICS OF YOU LAYING ON THE GROUND, WELL HIDING OUT UNDER THE CAR, PRETENDING TO BE WORKING, OCASSIONALLY SCOOTING OUT FOR A TOOL OR SOMETHING. IT SURE LOOKED LIKE YOU WERE LAYING DOWN ON THE JOB A LOT! :poke:
SURE YOU WANT THOSE PICS? :headbang:
I can't wait to make a fool out of myself and give Bob more reason to pick on me!!!! ehehehe :D
I have no idea how you made a fool out of yourself, this time. I must have miss out on that one.
You did the work and found the new valve right where you put it ( under the car with you ), even though he came out from under the car looking for it. :poke:
I guess there was the ramp thing. :poke:
Or was it the carsoft thing. :poke:
Besides , I only pick on people I like and know they can handle it. Just look out if I ever stop picking on you. I think you are safe until you teach me how to do brakes, change oil,change wiper blades, show me how to shift my steptronic, :evil: use my turn signals, use my brakes and vanos anyway. :oops: As a matter of fact, the only thing I will most likely never ask you to show me how to do is clean my car. :poke:
