srhutch said:Try tapping it. Failing that remove the battery for 30 minutes or so. Last resort would be to remoce the changer and then take to bit to remove the CD's
I had to do this years ago after my uncle pulled his change out of a car before selling. Of course he forgot to eject the CD's first.
philip27 said:This happened on my car I used a very small flat head screw driver to flick the disc up and it jumped into life the magazine then ejected. It's happened a couple of times and this is how I fixed it. Obviously just be careful and don't force the disc up to much.
Bing said:Disconnecting the battery basically reboots lots of systems in the car - hence why the clock and the windows need re-set once you've done it. But you have to leave it disconnected for 30mins or more. Hopefully the CD changer will reset itself when the power is reconnected and you switch the ignition on.
Bing said:Clock - use the head unit.
Windows - you lose the auto-up/down function. Re-set is ignition to position 1, press both buttons to put the windows all the way down, hold down for 5 secs, then pull the switches to put the windows all the way up, hold for 5 secs... Down and hold for 5 secs, up and hold for 5 secs.
You'd be amazed what disconnecting the battery can sort. You reboot computers that stop working all the time right ? That is basically a power cycle re-set... A car is full of computers, this is the same thing. Worth a go, and if it works you won't scratch your trim any more trying to lever the tray in![]()
Bing said:I know, right time right place mate, I'm a finisher dontcha know :wink:
