Jfgoldfish
Evening all.
My zed is showing symptoms of a failing CCV; poor idle, intermittent periods of higher oil consumption and intermittent puffs of smoke after long periods of idling.
I have ordered a Febi Bilstein kit and will be replacing it some time in the next couple of weeks.
I believe the intake manifold absolutely has to come off to do this job on the N46 2 litre engine so I ordered a set of manifold gaskets too.
Is this true?
I have read that the crankshaft sensor should be replaced at the same time as preventative maintainance. Does this apply to the N46? Is this really a common part to fail?
Anyone who has done this job on the 2 litre before, please point out any tricky bits or advice that may make the job easier.
Thanks all,
Jay
Is this true?
Thanks all,
Jay
