RobbiZ4 said:Might be interesting to test an individual value like i.e. 15kph/0x0F, if you are able to code it on a byte/word level.B21 said:…or the hex code in the CTM is 1E![]()
I will check it the next days with my BimmerCode tool.
Yup that’s what I did using Protool..
In the CTM coding > Expert, search for this option using the magnifying glass - GESCHWINDIGKEIT, set to a custom value xx and then code it. That should raise the limit of the top being closed and opened to yy kmph
