flybobbie said:Could be driven above max. speed with roof not latched. Faulty sensor somewhere.
IT IS "driven too fast while not latched", nothing else. Might have happened ages ago and doesn't matter at all. Only base for new rumours.flybobbie said:Could be driven above max. speed with roof not latched.
RobbiZ4 said:IT IS "driven too fast while not latched", nothing else. Might have happened ages ago and doesn't matter at all. Only base for new rumours.flybobbie said:Could be driven above max. speed with roof not latched.
And please, once again, no WD40 anywhere in the roof's construction!
To check CC codes use one of the following pages:
https://www.autobulbsdirect.co.uk/blog/bmw-cc-id-error-codes/
https://www.drive2.ru/l/4628359/
https://bimmerguide.de/check-control-meldungen-e-modelle-v1/
RobbiZ4 said:And please, once again, no WD40 anywhere in the roof's construction!
Oh, what a boring Z4 life. :rofl:acm said:That was my one and only transgression... honest! :lol:RobbiZ4 said:And please, once again, no WD40 anywhere in the roof's construction!
RobbiZ4 said:The question was regarding the following fault code:
CC-ID 271 Convertible Top, Vehicle Speed
It means, that the speed of the car was higher as the speed limit configured in the CTM, the roof control unit.
This limit is depending of the age of a Z4 E89 as well as of the inidividual coding status. Standard limit in the first years was 6 km/h, not more. Later models got higher limits up to 30 km/h as well as 50Km/h as of about 2012.
ID 271 does not indicate more than the simple fact, that the driven speed was higher than the configured CTM limit while the roof was not completely latched. That is not an issue, nothing is broken or needs any grease.
There is nothing to reset, there can't be anything resetted at all. It is only the documentation in the list of fault codes, that this limit has been exceeded.
The limit can easily be increased, e.g. with Carly. But...B21 said:Good to know …any reason why say a 2011 car cannot be programmed to a higher speed?
Yes, indeed, that is correct. But this limit initially was set to 6 km/h, which never ever could damage anything.flybobbie said:I thought it records break speed limit to tell dealer that a strain may have been put on the mechanism.
Otherwise why bother.
I thought this code had come up when driven with roof unlocked.
RobbiZ4 said:The limit can easily be increased, e.g. with Carly. But...B21 said:Good to know …any reason why say a 2011 car cannot be programmed to a higher speed?
There is a special situation in which problems with the roof shells can arise when opening while driving. That was the reason why the hydraulic pump got an additional solenoid in 2012 (the 4th one), an extended hydraulic harness as well as an improved CTM, that is not compatible with the elder Z4. With these improvements, the speed limit was raised up to 50 km/h.
Without these improvements a low risk remains. I would not recommend to change this limit on a higher value than 30 Km/h.
Yes, of course.B21 said:30 kph works for me thnx better than 5-6 kph :driving:![]()
RobbiZ4 said:Yes, of course.B21 said:30 kph works for me thnx better than 5-6 kph :driving:![]()
But don't expect mph! I'm only aware of 6, 30 and 50 Km/h. Don't know, if there are translated units available in the UK versions of the CTM.
Might be interesting to test an individual value like i.e. 15kph/0x0F, if you are able to code it on a byte/word level.B21 said:…or the hex code in the CTM is 1E![]()
