Carver Audio System Advice/ diagrams
bola
Has anyone got a diagram of the carver amp/DSP system? I have no sound when the head unit is switched on and running. Sometimes it works and sometimes it doesnt, when there is no sound there is no voltage to the connectors on the amp (6V) i have replaced the head unit with a second hand one and it hasnt really improved the situation. Anyone had the problem before or have access to diagrams of the sound system? It isnt related to the GM5 module is it?
Also the amp isnt/hasnt been wet.
Go to http://www.bmw-planet.com/diagrams/release/en/e85/index.htm.
Drill down under complete vehicle>body>audio video, navigation. You will find it's not one comprehensive diagram, you'll need to hunt around some to find all the related components. Once you've identified a component by code number, more information is found in the components section. Unfortunately, at least on my browser, the hot links do not work.
I'm pretty sure the GM5 does not play into this, it'll show up in the diagrams if it does.
