CarPlay/AA MMI box with MOST connection
(555 said:
[ref]AnubisZed[/ref], is there a video for Z4 e89 yet? Looking forward to get my teeth into it.
Completed a walk-through of the video content today and a voice-over plus some more footage, so it's nearly there, alas far too many personal things have got in the way (and are still) just recently so they have had to come first :(
I can answer any questions in the meantime though. :thumbsup:
Hi buddy, I hope everything is under control at home.
Mhmmm, I would have way too many questions to ask as I haven't undone one single bolt yet. I'll better wait for videos, comments and then think about giving it a go.
Do you know if it's possible to keep the standard BMW Menu or on the contrary you'd loose it as consequence of replacing the "hardware box" (the MMI, ain't it?!) Because I'm happy to add features to the car but keeping original stuff, even if it's the software system.
PS: any idea about TPMS, did they exist OEMs?
All original menus etc are exactly the same as currently, this mmi just runs in the position of the CD Changer as an album.
If you dont have CDC then ill include how to sort that in the video. :thumbsup:
TPMS was the later system, whereas FTM was the preceeding system, both work with either iDrive or non-iDrive.
TPMS uses sensors/transmitters in each wheel valve and FTM uses the ABS sensors to determine the wheel position/height
One question ..given that firmware updates need access to the box ( I know there are sd card extenders)…what’s the negatives and can you mount the box in the glove box?
I realise that firmware updates will be very limited in time before it’s obsoleted?
I have installed mine behind the radio unit but near the bulkhead to the motorroom. There is an area that can store the box pretty good. You will have a good access to that area when removing the trim (4 torx screws) above your pedals. No need to remove glovebox and imho better to guide the cables to there as well.
I placed it there with future firmware updates in my mind.
I also bought a micro sd card extender but did not install it because according to mr12volt update procedure you need to disconnect cabling during the update as well (see link below)
https://www.mr12volt.com/pages/p2000-series-software-updates
I have some issues with my unit, the video of the original menu glitches after using the box for a short while and switching back to the cic.
I have an open ticket with mr12volt but their respons is currently lagging a bit. Confident it will be solved though.
Had some time to test it a bit;
  • System is very responsive and starts very quickly
  • Sound is very good, enough bass, even with build in eq flat
  • Volume is slightly lower than radio
  • Display contrast/brightness with standard setting very good
  • Display dims a bit (not to nightmode) when light turns on during daytime (driving through a tunnel)
  • OEM PDC kicks in automatically on my manual drive (front and back), also when using the PDC button in the switchpanel
  • Box switches on and to carplay mode when selected as audio source
  • If music was playing when switched off, it continues after restart.
Received respons from mr12volt today. They did not solve it yet but apparently they tried to replicate the issue by installing the unit in 2 different E89’s with CIC. Now that seems like quiet some extensive investigations and troubleshooting…to be continued.
Provided them with a video of my “glitch” symptom that only seem to appear after using the box.
Anyone here that installed the latest version of the box successful on oem cic without (these) symptoms?
Made some pictures of the location. Have used some velcro to stick the box to the ventilation box while still being able to remove for future software updates.
Currently my box is in process of replacement by mr12volt. They had no other solution for the glitching other than to swap the unit and cabling as a complete set.
Wolter said:
Can you do everything through that side access from driver's leg room, or you'd need to remove the radio/cd system and mount it in that location from the front of the dash panel (ahead of gear stick)?
Initial installation requires radio/cd and gearstick trim removal as well. Depending where you put the mic also steering column cowl.
Future software updates requires only the drivers leg panel removal.
mcbutler said:
How can you tell if you have the CDC required?
Not sure what you mean exactly but after initial installation of the box the correct parameter automatically showed up in my CIC.
Guess once powered up the mr12volt box modifies the required parameter in your cic.
Afterwards in my case it took some trial and error and finally a cd in my radio cd player to get everything working; by that I mean mr12volt box showing up as a cdc in my cic multimedia menu. Once I could select it the mr12volt box properly showed up on screen.
Mounting-wise, you have a few options.......
1) Lower the glovebox and stick it to the top of it, this way you can also feed the trailing USB cable through the back of the glovebox.
2) Using zip-ties strap the box above the glovebox, again the USB can go into the glovebox.
3) Remove the dash front panel and slot the box into the space behind the air-con controls. This is a good fit, not too tight and supported enough not to create any rattles. Downside is that the USB won't reach the glovebox openings, so another location for the USB has to be found.
All three options will require you to remove stuff for a firmware update, but this is not a common occurrence anyway, so no real issue.
There are two ways....
1) You have a CD Changer in the glovebox
2) Your car left the factory with CDC Prep (VO Code 694). How do I know if it has VO 694? Go to bimmer.work and enter your VIN and it'll give you a list of the specs your car left the factory with. If you've got 694 then this should automatically sort itself and display correctly.
If you don't have 694 then this can still be coded to work and is a very quick coding to perform.
:thumbsup: I like the location, seems a nice tidy solution. Would it be OK to use these photos in my upcoming video?
Video update**
Sorry guys, more delays still. A general lack of time and the constant additional options I keep thinking of (which I then have to check and video/photo).
I think it's now 90% there so need to do an intro and titles for it and it should be ready.
