Carly
Tinker15
Holmfirth, West Yorkshire
I’ve recently purchased the Carly dongle for iOS and run a diagnostic check. The first run produced about 20 faults which I cleared. I’ve now only one fault left which is:
Dynamische Stabilitaets Kontrolle / DSC
Fault Code: 006F72
Fault Explanation: :JBBF Embassy VEH MOD (0x315) does not
receive wrong or DLC message / EMF: Embassy VEH MOD (0x315)
does not receive wrong or DLC message
Should I be worried?
Nope, its not on the fault code database so unlikely to be serious or relevant to operation/safety etc.
Modules give out codes for all sorts of things, you can gat a stability/ABS code if your wheel spins a tiny bit in the wet for example.
It even goes as far as reporting missed 'events' in the clock timing of the whole computer system which have no bearing on anything in reality.
So, if its not on the database I would clear it and see if it returns.
Thank you for replying. I’ve cleared it once but it reappears when I do another scan. I’ll try again tomorrow to see if anything changes. If it is still there I will put it down as one of those things and ignore it! 😉
