Carly issues (and OBD2 reader/code clearer recommendations)
groovy_hippy
 Derby
Hi folks, been a while since posting but still zedding :driving:
We've got a Carly 2nd gen wifi version. It'll get 90% through reading (or clearing) error codes then appear to freeze up (lights stop flashing on the dongle too). Leave it for 10-15 mins and it might sort itself out, or it might just stay frozen. It used to be brilliant and quick but having used it recently it's almost caused a marital!! :ROFLMAO:
Wondering:
1 - if anyone has had similar issues with Carly?
2 - what alternatives there are to Carly at the sub £100 mark. We need something that can read and clear error codes. Not too worried about coding things like auto locking doors etc.
Ta in advance!
Yep same issues
Gets to 90% then freezes
Only on z4s annoyingly works perfectly on all other bmw variants
I put in multiple support tickets to Carly and frankly they were s**t at doing anything about it
So I binned it
My creator 410 does all I need apart from the coding
@bigwinn - Funny how it's just Z4s!! Pleased it's not just us though...thought we were going mad.
@nikijack - typical right....not cool. Especially since it used to work so well!
Sounds like a Creator 410 is the way to go. I've read about Autophix too - are they any better/different? Or is it just a case of preference/what you've got and like?
I use Autophix. I believe the only real difference is that with Creator you have to select each module to scan individually. Autophix allows you to do this too, but also gives the option of doing a full system scan.
Interestingly the creator will full scan on other BMWs and on later z4s it also allows a full module scan
When I had Carly is was fine and worked on my Zed, my 5 Series and a friends Audi every time and even managed to code the roof, light and dash on all of them too.
Try using a the free app Car scanner with the Carly OBD Dongle as that works fine too and I keep that in the Zed.
@Jollygiant Carly used to work fine for us when we first got it - 6 or so years ago, but its just got progressively worse to the point its as good as unusable now... :(
@Rockhopper the Topdon ones look really good but a bit more than I wanted - that said, maybe in a few years depending what happens with the car...
@enuff_zed I picked up an Autophix on eBay, looking forward to tinkering with it. I liked that their website has software updates on it vs Creator didn't seem to have a website? Horses for courses probably but the Autophix one is orange :)
The Topdon will so almost every car on the road, you can advertise code reading services on your local Facebook group - make yourself £25 each time.
