Carlube siicone grease-
andysat
Hi all-this should be okay to run round the top of my boot seal shouldn't it?-I have heard silicone is bad for rubber but on the box and tube it states to use on rubber door seals etc?
Hi Andy, I think silicone grease is the same as plumbers grease & ok to use on rubber seals-it's normal grease that's a no no as it rots the rubber.
Regards
This is what I use
http://www.ebay.co.uk/itm/Silicone-Grease-Multi-Purpose-Grease-Water-Repellent-Carlube-70g-Long-Lasting-/121401160531?hash=item1c4412b353:g:2sMAAOSwPhdU5hHE
I'd recommend this stuff
http://www.micksgarage.com/ProdDetails.aspx?pid=1584628&AffiliateID=32475&utm_campaign=google_base&utm_medium=shop_channel&utm_source=google_base&utm_content=&utm_term=&cnty=GB&gclid=CL2Jkci75soCFUgW0wodqdkDcQ
Regards
Cheers mate :)
firebobby said:
This is what I use
Yes that's the one I have. :)
Yes got some of that aswell :)
Just a thought
But you can get rubber grease
As I used to use in my old 205 gti sunroof:)
Or Vaseline
andysat said:
How long would it take for Vaseline to destroy the rubber seal tho?
I'd reckon it would start to soften it fairly quick and over the course of a few months cause permanent damage and swelling to seals. Guess it depends on amount used, temperature, porosity if seals, etc.
Aside that it's messy to apply, water soluble and will attract all sorts of dirt and crud.
