Car parts searching problem
yct1012
May I ask why there are minor difference on the car parts number?
I want to buy a abs pump
Real oem shows the parts no. should be 34526769165
There are parts on the internet which is 34526769164
Is it still interchangeable?
Quick check on the part numbers using RealOEM.com shows that 34526769164 dosn't exhist.
it comes back with the message 'The specified part 34526769164 was not found.'
A search on 34526769165 shows it used on the following models and has been superceeded by new part numbers
34526769165
Repair kit, control unit DSC
01/02/2006
To:
08/28/2006 (ENDED)
Weight:
0.825 kg
Price:
Superseded by:
34526778492
(04/01/2006 — 09/06/2018), Exchangeable retrospectively
34522460456
(08/01/2018 — ), Exchangeable retrospectively
It looks like you need to find a replacement with the superceeded part numbers to suit the year of your car, if you find a original 34526769165 bear in mind it could be older than your failed unit and in no better condition.
Found this on ebay from Germany https://www.ebay.co.uk/itm/34526775395-ABS-DSC-Steuergerat-Reparatur-BMW-M5-M6-Z4-24048-24049-Pumpenmotor/172568050038?hash=item282ddb7976:g:Sd4AAOSwux5YVSZA
34526769165
01/02/2006
To:
08/28/2006 (ENDED)
Weight:
0.825 kg
Price:
Superseded by:
34526778492
34522460456
The one you shared from eBay is not a spare part
They provided repair service
Yes rebuild service, if you want a UK supplier try these people, they may be able to come up with a replacement or repair yours https://www.ecutesting.com/product-catalogue/bmw/z4/abs-pump-ecumodule-combined/
Is the for pre or post facelift. I have a post facelift one available. There are only two versions post facelift from memory.
What is the issue with yours though as most are repairable.
