Hello everyone, first of all, I really appreciate you to open and read this topic. I really need your brilliant knowledge of Z4s now.
[OVERVIEW]
Vehicle: 12.2003 Z4 3.0l (EUR)
Steering: LH
Gearbox: SMG
VIN: WBABT51020LR89***
Issue(s):
1. The passenger door lock would not unlock with a keyless remote
- can open from inner handle
- inside lock/unlock button also does NOT work
2. outer door handle on the driver side does not work properly; quite heavy.
- inner handle work perfectly
- sometime it does not work at all
[WHOLE STORY BEHIND THE ISSUES]
I and my partner bought used 2003 E85 a month ago from a reliable guy meet on the internet. Then he told us that the keyless remote is not working properly. When try to unlock the key with it, only the driver side would unlock, but the other side wouldn’t. Because of that, we had to open the door on the driver side first and then open the passenger side from the inside.
However, last week we found out that an outer handle on a driver side door doesn't work smoothly (I felt like it's heavier than usual) as the other side does. Because of that, we started to search the problem there on the internet, but yesterday morning, it finally stopped working. At that moment, because of the combination with issue-1, we had no way to open any doors (except for a boot door)
Fortunately, I kept trying to lock-unlock again and again, then somehow the passenger side door did unlock. In the end, we could enter into the car luckily, but we do not feel comfortable when close and lock the door again since it happened. At night on the same day, we went back to the car and tried to unlock the key, again, only the driver side did unlock. Most weirdly, then we could use the outer handle on the driver side (yet, it's still heavy-ish)
Have anyone been in the same situation in the past? What do you think is the solution for both issue 1 and 2? We guess that we need to replace front door lock bowden cable (#7 on a diagram 47_1477) to solve the issue-2. Do you think the same as we do? We definetly need your advice for now.
Anyway, no matter if you can or can not help us, we do THANK YOU so much for reading this quite long topic.
[OVERVIEW]
Steering: LH
Gearbox: SMG
Issue(s):
