Chippie said:The car not unlocking with the remote is probably a flat battery either in the car or remote, do you have a 2nd remote?
The remote can be changed from an electric toothbrush charger or a wireless phone charger.
The door lock can become seized, try squirting some lubricating oil in a keeping turning the key from side to side and see if it frees up.
If none of the above work then you may need to change the car battery, easier said than done.
You can open the bonnet by removing the front wheels and arch liner to get access to the bonnet locks, one each side, you may be able to open one and wedge that side of the bonnet up and then do the other side.
Alternatively if you remove the engine under tray you should be able to get to the thick red cable that’s attached to the starter motor, if you can attach a battery charger to it and an earthing point you may be able to get enough power to activate the central locking and open the door and boot.
If you can get into the car with the door lock but can’t open the boot you will need to access the fuse box in the passenger footwell and jump a fuse there.
Here’s a link for that
https://z4-forum.com/forum/viewtopic.php?t=144888
Hope this helps.
Timhouse said:Hi. Tried the other key fob. Didn’t work. Tried the mechanical lock loads didn’t work and so I guess it’s a dead battery and no way to access it.
How long is "a while"?Timhouse said:Hi everyone.
My e89 has been sat on the drive for a while.
paul1969 said:Managed to get in!
The key fob wasn’t working and I couldn’t get in with the key either at first. I sprayed some WD40 into the door lock barrel and worked the key side to side for about 10 minutes. Then I gave it another spray and left it for about half an hour. After that, I tried the key again — and it opened straight away.
Once I got the bonnet open, I connected a battery charger to the under-bonnet jump-start studs. After about 30 minutes, it gave me just enough power (with the charger still connected) to press the unlock button on the fob — and that opened all the doors and the boot so I could finally get to the battery.
Hope this helps someone in a similar situation!
PBondar said:I think that was what we advised !
But glad you worked it out..
Then locked the door manaually, tried the boot and ... the alarm went off. :?Busterboo said:Glad you got it, paul1969. Now, I'm going to oil the manual lock and the shafts of both keys ...
