Can't find partnumber
ryushe
 Rotterdam
I've got a project in mind which involves drilling or cutting into the downward facing panel right under the climate controls. Basically the panel that usually seems to be used to fit the AUX connector. It's my preferred trim panel to use as it's easily removeable, and since it's downward facing whatever I want to install behind it won't be very obvious.
Now, just in case I mess up for some reason, I thought it would be a good idea to get a spare. So I've tried finding the damned panel on RealOEM, but all I can find seems to be the panel with the cutout for the AUX connector already present. Can't seem to find the original style panel part number. The replacement panel with AUX cutout should be number 3 in the diagram at this link: https://www.realoem.com/bmw/enUS/showparts?id=BT31-EUR-10-2004-E85-BMW-Z4_25i&diagId=51_4949.
Can anyone confirm if part number 51459128397 is what I need, or if I'm wrong and my assumption that it already has the cutout in place is correct?
Thanks!
Barty said:
51457053091 in case you need it before removal
Thanks much, however as @Zedebee mentioned that's the panel with the cutout. Interestingly enough that part number is not even mentioned at RealOEM.
Either way, will get the panel out today somewhere and get the part number, but appreciate the help!
I still have the old panel kicking around, I think. PM me if you need it, but it does have the aux cutout.
https://www.ebay.co.uk/itm/363428153302
Maybe cheaper options out there? But still cheap enough :)
item 3 in future https://www.realoem.com/bmw/enUS/showparts?id=BT52-EUR-09-2003-E85-BMW-Z4_30i&diagId=51_4949
Sorted, seems the panel listed as having the cutout for the AUX connector is actually the original panel I need. Called my local dealership and they confirmed it. 51457053091 is indeed the correct part number.
Thanks all for the help and links!
