Can you fit 5 series alloys on a zed?
andysat
Hi all-as above really,ive been trawling through fleabay,and some nice alloys (17 inch) that have come off various 5 sreies have been cropping up,but will there be any probs using them?-thanks
The E60 17" wheels have an off set of 20 and the Z4 46 I think that's quite a difference. Maybe someone who understands offset configs could help. :driving:
also, the centre bore is def larger on the e39, not sure of e60, so you would need rings to go in the wheel centre if you could find some with the correct offset. think theyre 74mm centres........
Fitting a 26mm spacer would do the trick. However 26mm is an odd size!
With the majority of vehicles you can add spacers to effectively increase offset. But it's not possible the other way round.
Certain offsets work the other way, but it's long time since I've had to explain it :lol:
Thanks for the input chaps-i may wait it out on here to see if someone has an excellent set of 17's with excellent tyres delivered free for £300 :)
