weegeoff said:Why don't you just reverse in It saves on petrol :!:
Scooba_Steve said:And it is, I've given you 2 options. Disable permanently or manually with a switch.
It would be a possibility to disable with a push button until reverse is selected again but that would require:
a) someone smarter than me
But he still has to drive out forwards with the engine cold so how does this not just cancel out?weegeoff said:Think about it. when dose your car use more juice. when it is cold. when you come off your run The engine is warm reversing in will use less juice , Simple!!!![]()
No your engine will warm up quicker going straight on your run, you drive out of your garage turn left/ right or what ever and even save a bit of wear on the engine and gearbox.GreyZed said:But he still has to drive out forwards with the engine cold so how does this not just cancel out?weegeoff said:Think about it. when dose your car use more juice. when it is cold. when you come off your run The engine is warm reversing in will use less juice , Simple!!!![]()
Scooba_Steve said:And there he is ^
:lol:
I've not looked at the wiring diagrams but assume that would be a little fiddly at best.
So 3 options.
Ducklakeview said:Scooba_Steve said:And there he is ^
:lol:
So 3 options.
Little bit of Veoboard, a relay and a couple of wires in a matchbox sized enclosure, prob cost less than £5 to make.
Mike
