Can you adjust your windscreen?
Obicoke
Blackpool
I have an E86 and the rubber around my windscreen has perished. I bought a new bmw rubber and tried to fit it. I can't fit it. The gap at one side is way smaller than all the rest. So it must have moved. I just can't push it in.
The only thing I could do it cut the rubber and glue the rest down, which I don't really want to do and would be a complete bodge job. Is it possible to move down/adjust the windscreen somehow or will it be fixed solid? So in other words its a complete windscreen out and in job?
Obicoke said:
j3nks79 said:
It’s bonded in. You would need a screen company to remove it and re fit it.
thanks, appreciate your response. So annoying that.
And expensive!
Have you tried to lube the seal to see if that gets it in place? Or is it miles out?
Also a bit of heat on the rubber. But be careful not to crack the screen.
I recall another thread saying it wasn’t easy (compared to the e85) to change the surround
May be worth a search
Did you dunk the thing into some warm water before you tried to fit it? I did that and it made it way easier. Granted it was on an E85 and not the 86.
I recall a thread on another forum from someone who ordered a coupe windscreen seal, but received a seal for a roadster - it did not fit. Any possibility you might have a similar issue?
I replaced the trim on my E86. Less than an hour to remove the old one, clean the junk, fit it (incorrectly) remove it and fit it properly.
It's a simple job...I've no idea where the "it's difficult on an E86" thing started
They're was a good few mm difference in both sides. So I cut out the middle bit with a scalpel. Pushed it in and it looks OK. To be honest if you weren't looking for it you wouldn't see it. So happy with that for the time being.
