Had new tyres fitted at the end of last week (225 45 17 Falken FK510) and as noted in this thread, I took the car for good long run to see how they performed. I had an alignment done at the same time and there was a fair bit of adjustment made around toe and camber – details are in the photos below.
Once on the road it soon became apparent that these adjustments and or the new tires, have completely transformed the car and unfortunately for the worse! At speed it tracked all over the road and at times in a dangerous manner. The car has completely lost its sharpness when cornering at speed; there is no balance coming into corners, no feel for grip or balance until you have turned in at which point you again feel where the car is at for grip and balance. This is totally opposite to what it was like pre-new tyres and alignment; there was always a very strong sense of balance, grip and oversteer/ understeer. Genuinely feels like a completely different car.
So, a few questions around this to see if you guys can help me out and get her back to where she once was;
I clearly need to make some changes, but I am unsure what they need to be .....
As usual, TIA
- I have only replaced the rear tires, still have originals on the front, same sizes all round
- Tyre outfit had her down as an E89 (as it was first registered in 2009); does this make any difference to what the camber and toe should be set at
- No other changes to the car since old set up
- Do you guys run any specific settings for toe and camber, or do you leave it up to the wheel fitters
As usual, TIA
